684door
For sale is an unmodified 8 3/4 housing with 10x1.75 backing plates, brakes, 5x4 drums, and 5x4 axles. Also included is a 489 case open carrier center section with 3.23 gears and a cone style sure grip unit. I am switching to a Dana 60. I have had this housing under my car for 25 years. The housing was painted yrs ago with Por 15 and other than being dusty is in great shape. The drums and backing plates were blasted and painted in Por 15 as well. This comes with the rubber brake hose and attached housing vent. The other brakes lines that run to the wheel cylinders are attached and included. No center section. Dr.Diff told me that this is a rare find due to most housings have been cut up or molested in some form. This have never been messed with. Was told value is anywhere from 1000 dollars to 1400 dollars complete like I am selling. Asking $975.00
If interested in the rear end. I have set of small bolt pattern 15 x7 steel wheels that are 4.5 backspace. I had 255/60 15" wheels on these wheels and had perfect clearance on the outside wheel lip and spring. I also have a set of wheel vintiques small bolt pattern wheels 15x7 4" backspacing that I ran 225/70 15" street tires on. Both fit great. This was on a 1968 Dodge Dart.
Rear end setup- $975
15x7 4.5 backspace wheels- $95 a piece
15x7 4" backspace wheels- $95 a piece
Tires not included. Only will sell if rear end sells.
Located in Pittsburgh, Pa
Preferred pickup
Preferred pickup
