cherokeechief79
Were doing a usct spring relocation on my sons 68 barracuda.
It will also have the inner wheelwells widened.
We were going to tackle it ourselves but a friend has offered to do it and he has a plasma cutter and a good welder.
The axle we have has been narrowed 3 inches per side and has axles in it but just a dummy centersection with no gears or pinion.
Can he set the pinion angle ok like this or will we need to get a loaded centersection in it?
Its got superstock springs and he wants the back end raised for big tires.
We drilled a new hole in the front spring mounts that moves the rear back 1 inch to help center the tire.
