carrmann
Selling a rear end I had for a project.
8 3/4 rear (for an A-body). small bolt pattern (sbp) axles installed, open diff with tall gears (most likely 2.76). Everything still rotates freely etc. No brake components. (450$)
Also have a 3.55 gear posi 489 case 3rd member (for a 8 3/4 mopar rear) that is all setup and ready to install. (450$)
green bearing large bolt pattern (LBP) axles also available and extended studs. (300$).
mopar under dash a/c unit with pump etc. Lots of parts. (200$).
Will let it all go for 800$.
I do not want to ship... would be too much of a pain. I live in Oldsmar FL, and will be moving to Davenport FL (west of orlando) this week. So I can 'deliver' within that range if necessary.
