8 3/4 rearend bearings
34072demon
Active Member
Minneapolis, MN
I recently had my rearend soda blasted and they recommended that I replace the seals and the bearings and hosing out the interior. Can I get away with using a solvent to clean out the bearings and repack them and install a new interior seal? If I should replace the bearings what is the best way to remove and install them?
