[WANTED] 8.75 complete 10.25 drum Brake assy & 5x4.5 axles
OllieDemon45
Mid Michigan
I want to convert my 8.75 rear end to BBP axles and would like to find complete 10" drum brakes as well.
The backing plates are hard to find and i have know idea where to find a complete assembly. Dr. Diff does not have any stock.
Anyone have any for sale? I was debating on a complete rear end as well since mine is open, but it does have the 489 center section.
May be open to different options.
Everything is stock right now with the SBP. The front has a disc brake conversion already with the BBP.
Located in central Michigan.
Thanks
I have this set of 10”x 2 1/2” bbp backing plates. They need cleaned up but you can see the wear pads are in good shape. A little smoothing on a couple and they are ready to use.
