[FOR SALE] 8.75 Rearend housing axles and backing plates $350
littleredcoffin
keene nh
Small bolt 8.75 Rearend that has been sitting alongggg time. It has Gotten a small amount of water in it. The oil that came out had no milky look, was dirty but not contaminated. Has some pitting on the back of housing and a bit in 1 of the tubes were the axle bearing race sits. The spot will clean up mostly. The bearings still moved but there is some pitting in one spot on one of the tubes, and 1 axle has some pitting on the end near the seal area where the housing has the pitting in the tube. The rearend does not leak fluid. The backing plates are not rusted out. Splines on axles are good. I have taken many pictures. I will not measure the width.. I will not take more pictures than I have listed.. It is a small bolt 8.75.With some cleaning and good prep work this will look nice painted all up in a little 340 car. Housing, axles and backing plates $350.I don`t think you will find a cheaper price on the planet.
I will not ship this set up..Keene NH.US Postal money order only.
