Hi All,
I'm going to be putting a edelbrock performer intake on a stock 82 5.2 that was org. a 2bbl, I'm unsure about the gasket, do I require the big $ ones from edelbrock, or will a stock gasket set do the trick?
Also,
I need to change the distributor from the dual pickup lean burn unit, any thoughts on a resonably priced replacement. I see on flea bay there are some units that are "ready to run", or the mopar conversion kit, I'm sure there are more but I'd appriate your thoughts
Thanks for the Advice
Cheers
Also,
Cheers
