83 Horizon 2dr (Turismo) Conv. to RWD
Terencejiminy
Member
Warren, Michigan 48089
Rating - 0%
0   0   0
1983 clean, solid and straight Plymouth Turismo 2dr FWD car converted to RWD. Done right.
Need a new unique home for your SBM? :cool:
Car has been off the road and out of the salt since mid 90's. Last powered by 4bbl 318. Basically just needs YOUR drivetrain.
Planned for a Slant/6 Shootout car.
Mopar Small Block Spool Mount s. I also have Slant/6 spool engine brackets.
Front steer Mustang rack & pinion. 5 X 100 (5 X 4") front rotors and hubs. Trans & Driveshaft tunnel for 727 or 904.
Aluminum interior panels. Shelby Charger Seats. Good glass, all intact. New door glass weatherstrip.
New rear hatch cylinders. Spare complete rear hatch.
Charger 2.2 Hood in pic was pretty sad so it's been replaced with a pristine stock no scoop hood.
It now has twin carb induction (inboard headlights) with screens and hose connections.
Set up for Mustand II rear leafs. No rear end. Trunk cut out for inset fuel cell. Rear battery box and new Cut-Off switch.
Clean solid floors and unibody.
E/mail me for Pics.
$1000 !!!
With clear Michigan Title !
Warren, Michigan
Local pick-up please, bring cash and a trailer.
Thanks,
Terry
terry.bogusz@spiritair.com
want to sale just the scoop off the trashed hood?
The original builder cobbled the scoop and stock hood together (sub-structure hacked away except for the outer perimeter), did a pretty POOR job. There were only two studs that weren't broken out of it (had JB Weld on the other ones) so I pitched the flimzy hood.
Precision Automotive has that scoop hanging on their wall in Windsor Ontario right now.
New set up with pristine hood and cold air induction through the inner headlights looks/works much better.
The people who did the Chassis structure and RWD conversion were much better at their craft.
Sorry....
Terry
