from the 99126 tail shaft housing it should be A body 69-71
thank You...
Yes correct. It´s actually a 18 spline A-Body trans. And the fact it has no vin # make it interesting to my SS/B recreation project.
Tran also has the Slick Shift modifications done to it, but seem to never have been used after that.
Question:
What race cars other than the SS/A and Pro Stock A-Body cars did use 18 spline 833:s in 1970. I mean could any 4-speed A-Body car have the 23 spline swapped to a stronger 18 spline? Did NHRA for example aloud for that??
Also, but no a possibility in this case, since this transmission is date coded November 12 1970, (thanks JoesEdge) did the ´68 SS factory cars have the vin number stamped in the transmission? I guess Yes... ;)
Is it possibly an over the counter back up trans to a SS or a Pro Stock race team? Can you pleas elaborate on that?...
Well what ever the history is on this transmission, it is a piece of gold to me, whether it was a back up transmission to Ronnie Sox or not
Not the best of back ground, no... Sorry about that...
