[SOLD] 833 O/D transmission
wish4hemi
P833 3007
I believe it is a 1977 model year.
O/D unit with 5.125" input bearing retainer.
B/E body shifter mounting locations.
Cast iron case (as opposed to aluminum in other versions).
I've never had it apart, so I do not know the conditions of the internals. However, it has been under roof for the 10 years I've had it.
$225
Shipping from 62448
PayPal or cashier's check
did U rotate the input 1 rev. and count output revs with the forward shift lever in both positions? 3007 is Oct. 1969. maybe the bearing retainer was changed?
I have not. However, due to the style of the tailshaft mount, the aluminum side cover, and the input bearing retainer, I assumed it was late '70's. Will do more research this weekend.
Correction on the date code. It is 8007 which means it is a 1983 transmission.
