[WANTED] 833OD shift levers
dgswinger
south central pa
I'm looking for a set of shift levers that bolt onto the side of the trans of an 833OD for an A-body
If you have any that are correct and would want to part with them please PM me
Also F-body is the same
Thanks Derek
I was having a hard time finding a set, so I ordered new ones from Brewers. I'm thinking they were around $150 and they came with clips and washers.
Sounds like you needed the shift rods... I just need the levers that the rods hook into.
Brewer's has the lever set for 39.95, but it is for the truck OD. I don't know if there's a difference or not. Call them and see.
What are the numbers you need i have quite a few O/D levers PM me
Let me know the #'s that are stamped on them when you get them and i will let you know what i have and price
I really don't know the #s I need... I have all ready purchased a set from a FABO member earlier today but will take a second set for the right price.
