[FOR FREE] 9" Front Dums, upper control arms, spindles, etc.
J Glenn
Minneapolis
Rating - 0%
0   0   0
I've upgraded my front-end to disc breaks. These are the take-off parts.
Upper & lower ball joints
Spindles
Upper control arm
Front Drums with some life left in them.
Eden Prairie, MN 55346 (pick up only... )
Two quick questions . Any way you could get me the weight of one brake assy with or without the arm? Bathroom scale weight is good enough. I am going back to 9 inch drums on a project and need just the spindle with backing plate and the hub. If nobody can pick them up any interest in stripping it down to the basic parts I need? I am in Southwest Michigan area and could possibly travel after our shelter in place order is done.
I can weigh them... with a bathroom scale. But if I'm gonna ship them, they will not be free. I'd charge you $40+shipping. (The $40 dollars being hassle charge.... I'm trying to avoid the hassle.) I'd need to look at the backing plates, they might need to be filled and milled (ie, they may have some gooves. I assume you know what I'm talking about.)
The upper control arm with upper ball joint, spindle, backing-plate & lower ball joint are 25lbs per side.
There is a local guy that wants that one.... (I'll let you know if he fails to pick it up)
