dart540
All New Fresh Build No Runs 904 SM Blk Trans Has 5- clutch stock Drum with 6 Clutches and Kolene Steels A&A Spring Pack A&A Solid 1.6 Wide KD Band Red DW Rev Band A&A RMVB with LBA VB A&A Modified Output Shaft Rollerized Rear Support Lightened Park Gear Alum Spacer Replaced Gov Housing A&A Billet Low Rev Servo With HD Spring Acc Blocked A&A Billet Frt Servo With HD Spring 4.2 Lever HD Band Strut Deep Steel Pan with Drain Plug Low Gear Set Lighted Sun Shell Modified Oiling Mods Teflon Rings Race Prepped Case New Gaskets Seals Bushing A&A Bolt in Sprag
$2950 + Core
Pick Up or Can Ship
Western PA
$2950 + Core
Pick Up or Can Ship
Western PA
