[FOR SALE] 915 J heads, rebuilt and flowed by BJR Racing, never used, $1299
ramhi4x
Redmond, OR
Rating - 0%
0   0   0
Checked for cracks
Gasket Match
Comp valve job
Pocket port
Surfaced
Cut for 1.625 springs
Cut guides for seals @ clearance
Install new springs, retainers, & keepers
Flow chart attached
Also see: http://www.bjrracing.com/small_block_heads.htm
$1299 + shipping from 97756
Thanks for looking,
Paul
Are those still 1.88" intake valves?
Yes, 1.88/1.60. If you look at the flow sheet it says the valve size, the flow, and a simple formula for making 550HP+ with these heads. On Bobby's link above, he says he likes using 1.88's to keep the port velocity up;
"On the 340 engine you should use the 1.88 intake valve to keep the port velocity up in the larger runner. The same modifications that were done to the 318 heads will apply here also. A good 340 head with the 1.88 valve should flow in the 235/240 range @ .500 lift and 160+ @ .200 lift if the port is properly done. The same air flow will apply to the 360 engine."
Thanks,
Paul
I didn't even see the attached flowsheet, thanks!
