[WANTED] 96’ ish 46rh transmission 2wd
Syleng1
Karma is real and Life is short...
North Franklin, CT
I’m looking for a complete 2wd core for a Dodge truck or Dodge van for a mid 90’s overdrive transmission behind a 318 or 360. I think the 3.9 also had them but I am unsure.
I will need the drive shaft for the yoke and the converter.
I want to convert my 86’ Dodge van with a 318 to overdrive and lock up converter. I can rebuild myself. Sadly I’m in Connecticut, so pick up is limited to New England. (RI, Ma, Lower NH or Lower Vt. Parts of NY and LI)
I believe need a 46rh.
Thanks-
Syleng1
46RH, also referred to as a 518 is what you need. Pretty sure 95 was the last year. You want one with the 3 pin connector like in the pic below. Good luck with the search.
