99 Durango disc rear to my 64 dart?
tbr3
Hi,
Anyone know if a disc rear from a 99 Durango V-8 will bolt on to my 64 Dart?
Also, would this rear be an 8 3/4?
Thanks!!
Tom
No and no.
The only rear end upgrades that will bolt in to your 64 are from other A-bodies. You can either stay with the small 7 1/4" rear or go to an 8 1/4" rear from a 72 and up A-body or and 8 3/4" from a 72-earlier A-body if you are looking for a bolt-in. Either way you will have to have the driveshaft shortened.
Also the 8 3/4 rear end is the one with the smooth round back to the housing and the drop-out center section, very similar to a Ford 9".
That rear end is a 9.25.
It is going to be way too wide.
I agree with Optik on suggestions.
Thanks,
OldMoparsRule!
