[FOR SALE] A-230 3 speed setup A Body verion
Chris (CJ) Johnson
Long may you run, Cody...long may you run
Raynham, MA
Rating - 0%
0   0   0
I have a complete A-230 3 speed setup for A body cars. It has a 23 spline input and 26 spline output and is the 3.08 first gear version that came in A bodies and with full syncros (3 syncros). It was on a slant 6 and comes with the following: bellhousing, clutch fork, flywheel, 10 inch clutch w/ pressure plate (if wanted), dust/inspection covers, slanty block bracket, and 2 shifters. Casting date is 5-23-70. It had been swapped into a 1973 van and they cut a hole in the floor for the shifter and hacked up the shifter, too. I’m including another good shifter from my Duster. The vin stamp is not clear, but no visible numbers match the van, plus it has the floor shift boss on the tail, so it likely came from an A body originally. It’s clean inside and spins/shifts, but will need bearings and seals from sitting. Not sure what it’s worth, thinking $600 or swaps for A body stuff. Prefer local pickup but will ship fedex if you pay.
CORRECTION: CASTING DATE ON CASE IS MAY 29, 1970
I'd prefer to sell it all together hoping someone will want it all for a swap. I'll circle back to you if there's no interest. Thanks for checking.
H
Hi, is everything still available? I’m looking to do a swap in my 73” dart
