A-230 help
Jeremiah David
Active Member
Colorado
I have a 73 plymouth duster that I'm trying to find a part for. I have an a-230 transmission bolted up to a 360. I'm having a hard time finding a flywheel cover. If anybody can point me in the right direction it would be much appreciated.
My '70 Valiant 318 3-speed uses the same cover as the 318 & 340 4-speed cars, should fit all small block bells with the dual pattern (3 speed / 4 speed mounts) since the bells are all the same in this era as far as I know.
Thank you. I will have to look into finding one.
