TA head 69?
Picked up this brand new wiper motor assembly today from oriellys. 68.00. Direct replacement Except! The shaft for the drive arm is 7/16 not 3/8. You will have to enlarge the rectangle opening on the drive crank. I used a jigsaw with standard bimetal blade. Viced the crank arm, inserted the metal blade in the hole at an angle and turned it on. Slowly rotate the blade while it's running and it will enlarge the opening. Move the blade from one side of the rectangle opening to the other and it will fit snug. Chinese made. Good quality. Inexpensive.
