[Found!] A BODY 8 3/4 BBP AXLES
WAYNE0
milton pa.
I am working on a demon for a guy & talked him into changing it over to big bolt pattern. So i looking for stock 8 3/4 big bolt pattern axles for an A body. I live in Milton PA. 17847 Thanks As i know now they are going to have to be aftermarket and thats fine. They just need to be stock A body length
From Mopar? No such thing. Aftermarket only, and you will have to tell the supplier if you're using a-body or b-body brakes.
Or just weld up and redrill your stock axles and drums (mickey m).
If you weld and re-drill your stock axles and drums you will no longer have a register for the wheel if that’s important to you.
mmm really did not know that
