A.C. compressor mounting bracket for a /6
Ah OK. Then one off an M/J or possibly a F Body should be what you’re looking for.
I bought one of those mounts from another member but found it is useable only if a single carb, a 2 barrel or 4 barrel is used. It won’t fit when using a setup like a multiple carb system. I have my heart set on using MY triple Weber setup on my 47 Dodge
You can easily modify the one for the RV compressor to mound the Sanden. Been preachin it for years but nobody ever listens.
I bought one of those mounts from another member but found it is useable onky if a single carb, a 2 barrel or 4 barrel is used. It won’t fit when using a setup like a multiple carb system. I have my heart set on using MY triple Weber setup on my 47 Dodge
Do you have any to sell?
I guess you are talking about the main bracket that the compressor actually mounts to? There are like three or four brackets in the set. The main bracket, one that comes off the back and mounts to the head and one that comes off the back and mounts to I believe the driver's side motor mount bracket. To answer your question, yes, I think I do have a main compressor bracket.
so I would like to see it before i buy it. and the one that you have is for the drivers side?
I can send you a picture of the one I have which is designed for the rotary Sanden compressor. It is not a modified V twin bracket
