rod440
These were on my '69 318 Barracuda,it was for a Sears A/C system,should fit all '69 & older small block with the iron water pump,free if you pick it up,$20.00 shipped in lower 48.I also have the cast iron 3 groove crank pulley that you can have but I would need the proper steel 2 groove pulley to swap.All I have are the brackets & the pulley.Thanks,Rod.
