June of 2000 I bought a new tow dolly to move from Utah to Virginia. It towed my '71 Demon. I paid somewhere between $600 and $700 for it. While in VA I used it quite a bit locally. I then moved from VA to PA, and used it quite a bit there. I then moved to NJ and again, used it quite a bit. Recently I moved to OK and use it regularly here. Overall, I probably drug it well over 30k miles. I replaced the lights and fenders, welded up cracks, and tried to keep it greased. Well, on the last trip to NJ bringing stuff down, it pretty much fell apart. We literally lost a fender on I-80 in eastern PA.
Whereas previous repairs were mostly patch jobs, I decided to completely tear it apart, weld up all the cracks (again), reinforce obvious stress areas with additional steel, sand blast and paint it. Some of the cracks were on the bottom. I never had the table off before, so it explained why I kept getting cracks on the top.
With the table removed, I proceeded to disassemble everything, sand blast, prime, and paint.
