[SOLD] A518 4WD transmission
niceolddart
S.E. Pa.
I have an A518 transmission I removed from a running, driving 90 4WD 360 TBI RamCharger. It still has the convertor installed. It's dirty but was working when I pulled it recently.
Asking $175 for it but will not ship it, you come here & get it. In lower Bucks Co. Pa. 19030 Zip code.
No worries, I currently have a np208 on my ramcharger, but I thought you may have the more desirable gear ratio np241.
Anyway, I am interested in the transmission but trying to find ways to get it that will work.
I pass through that way in June heading up to Vermont for the summer, but unsure if you have any desire to store it until then?
I have reached out to a friend in Florence NJ to see if he has any ability to pick it up/store it, but haven't heard back yet.
Hopefully, I can make something work.
I think the NP208 transfer case is a more desirable case if I remember correctly. Gear driven as opposed to the NP241 chain drive but, I could be mistaken. Anyway, I have the trans in my shelter with the coolant lines plugged & out of the elements. I put it where it's really not in my way. The transfer case that was attached to it is a 2.72 ratio (See upside down pictures) Florence, N.J. is only about 40 mins. from me but, if you can't pick it up sooner, I have no problem holding it until June for you. Just stay in touch with your plans, OK?
