[FOR SALE] A833 transmission parts
ul4evr
Active Member
upstate ny.
Rating - 0%
0   0   0
there are enough parts to build a complete transmission.. most parts are in good shape except, the cluster and shaft are shot.. input is 23 tooth output is 30. i have no idea what this trans was originally in. it was in my wifes 72 swinger.. the shaft on the cluster dropped out while we were in gear and moving (had to drive it home in 3rd gear while holding the shifter in place).. the roller bearings, shaft and inner bearing surfaces on the cluster are trashed.. i swapped the tail shaft housing and shaft from the Dart onto a 81 aluminum case 3+od tranny out of a D100 pickup and this is what's left over.
$200.00 OBO
located in Putnam Valley NY. i can not ship will have to be picked up
