I just picked up a 69 Dart with a 340. Purple cam of some sort, headers, intake, etc. It is running an A904 with lockup converter that appears to be locked all the time. I've seen where you can use a ball bearing in the lockup valve to disable the lockup which I may do. Is there anything else I should look at first?
Thanks,
Jim
Thanks,
Jim
