MObarracuda
For those of you that are new to the hobby just in case you ever wanted to know what was inside the speedo gear. I had mine Apart todat and I took pictures. It is from a 1968 A904 from an EBody. Mine was leaking at the shaft where the speedo cable attaches. Was very hard to find the source of the leak. The threads were once cross threaded at one time so I replaced it.
Transmission Parts by Makco: Seal, Spedo Inner seal WITH spring, GM / Chrysler
