Mikey Yoh
Active Member
I am installing an additional trans cooler today. I need help identifying the inlet/outlet ports on the trans. I found only one reference to this in a Jeep forum, stating the front transmission line is hot, to the cooler (outlet) and the rear is from the cooler (inlet). Is this correct for an A904 transmission?
