[Found!] Abody 4spd steering lock bracket
Spadman
74 and still learning
Kentucky
Edit: I now have it all but the bracket that goes on the Bellhousing. I no longer need the steering interlock linkage that goes up to the steering column, or the entire set; only the one bracket.
Thanks , Spadman
This is the reverse column lock linkage? I have most if not all of the this except the column tube. Message me if Dave can't help you.
Yes, I am for sure missing the link up to the column. I’m okay on the tube. Thanks
I received the parts 1MeanA had but I still need the bracket that goes on the Bellhousing.
