Im in the market for some 2 bolt aftermarket main caps for my smallblock. There going on a stroker which has held up with stock caps and studs thus far. I'm porting the heads and going with a flat top piston. I feel like its time to step up the bottom end. I've read the cons of 4 bolt splayed caps on stock blocks so no need to go there. This motor should be in the 550-575HP range.
