air cleaner 2bbl to 340 4bbl clone
340wedge1971
Marblehead Ohio
I have a unique air cleaner for sale,you can take your 2bbl 318 and make it a 340 4bbl clone!,It may also fit smaller 4bbls from a truck,not sure.It has a carb opening of 4 1/8" and has been stripped and primered,comes complete with new 340 engine i.d. and inscruction stickers,and new lid seal.I will paint the base your choice of color,"Chrysler Blue" or "Hemi Orange".340 pie tin is not included,Located in Ohio,$125 shipped to lower 48.PM if interested.
If it helps, the 4 1/8" base fits early AFB's (400 or 500 CFM varieties) and 2 BBL Holley 2210/2245's. If you have a 2BBL mopar between the years of 1971 - 1978 with a 360 or 400 it would take this air cleaner. Solid work by 340wedge1971.
I believe the Carter 2BBL's are too small.
Thanks for the reply and info,you helped straighten out some questions i had about the applications this air cleaner will fit.
I found an air cleaner on ebay that was from a 71 dodge truck 383 2 bbl,looks the same as mine,just no (osac valve) on the snorkel.
