another fuel gauge problem
ev2duster
Helltown,Va.
The gas gauge in my 72 Duster is acting up. When I turn the key on, the needle moves from it's "off" position up slightly towards the empty mark. It goes to the same place every time & no further. Once I turn the key off, it returns to the "off" position.
Have you checked the wire back at the fuel sender, to make sure it is atleast making contact? Also make sure there is a ground strap from the sender to the hard fuel line.
