Another Kind Of 400
RustyRatRod
Caput villa stultus
Georgia
I know it's not a Mopar, but I thought some of you might like to see my Ford 400 eventually going back together. If not, then don't watch. lol
This is how I clean a crank after having it machined. This is not the final cleaning before assembly, but just to get the oil holes cleaned out. It's not Mopar, but it could easily be.
just what we needed, a vidya of some hillbilly playin' with his crank.
:poke:
great content, keep up the good work.
also, can you come over to my place and handle my crank?
Again, I realize this isn't Mopar, but this can be done to just about any domestic engine. I've even done this to my "Cheap and Nasty" slant 6 project. I drilled the main oil galley plug and tapped it for 1/4" x 32 to accept a Holley main jet. I'll screw a .040" Holley jet into the plug and then I'll have direct pressurized oiling to the timing chain and sprockets.
I also did an oiling mod to the front main saddle. There are two oil feeds to the front main bearing. According to Timothy Meyer, the oil pressure issue with these engines will be greatly improved by blocking the one pictured with a 1/4" pipe plug, as I have done and enlarging the second to 5/16". This helps divert that extra oil to the rest of the crankshaft, as the Cleveland engine family does not have priority crankshaft oiling. I also have some Timothy Meyer modified camshaft bearings on the way that will divert more oil back to the crankshaft. They have grooves cut in the back to act as restrictors. Instead of aligning the holes in the bearings with the holes in the camshaft bores in the block, you position the holes at about the 3-4 o'clock position which covers the holes in the block and makes the grooves in the back of the bearings the path for the oil to take, thereby restricting the oil to the top and diverting more oil to the crank. This also puts more bearing material right where the bearings have the most load, right at the bottom. It places the oil wedge in just the proper place to give the best wear for the bearings. At least that's the theory.
Here's the mods to the front main saddle. You can see the plug on the right side. The left side comes from the filter and then right to the main lifter galley, whereas before, there were two huge oil leaks right at the front main. This way, there will be much less pressure loss and really no loss of lubrication. You can see the horizontal passage coming from the filter and intersecting with both the now larger 5/16" main oil hole and the plugged oil hole that now only feeds the main lifter galley.
Is that for your truck?
Yes. It mysteriously lost oil pressure when hot right after an oil change. I had actually planned on pulling it to reseal the engine anyway, as it had some leaks and they are always easier to get to with the engine on the stand, but I had to pull it sooner than planned. So it's getting some oiling mods.
400m ?...where did the pressure go...
Just 400. The 351M was the only one Ford called M, but yeah that's the engine. I don't know. So far, all I've found was the new oil filter had a pin hole in the case. It wasn't even enough to make a difference on the dipstick after a 20 mile round trip to town......BUT the filter is VERY close to the oil pump, so that is a possibility. Bearings look great. Cam and lifters look great. Bores. All of it. And yes, I verified the pressure with a manual gauge. It was on the zero peg at hot idle. Plus the lifters were noisy.
Rob, have y'all got an Ollie's store nearby? If you do, run thru sometime and see if they have brake cleaner in stock in their little automotive aisle. If they do, it will probably be a dang site cheaper than everywhere else. Last I bought at Ollie's was $3.79 a can. I clean crank oil holes the same way, but I cut the long handle of the little barrel brush down and chuck it in the drill. Works pretty dang good.
RRR, why not just drill the plug to .040? too small to deal with?
That's a good idea! Thanks! We do have one down the road in Milledgeville. We go there usually at least once a month, sometimes twice.
For me it is. I'd break every dang tiny bit I have. The only way I'd be successful, MAYBE, is to use a hand held pin vise and I AIN'T patient enough for THAT. LOL
Tim Meyer? He was the Machine Shop Manager at the NAPA I worked at, and eventually managed, in the early 90's down in Savage, MN. He certainly knows his Fords, and his brother Tori is no slouch when it comes to FE motors, either! In fact, at one time Tori had quite the collection of FE "goodies" (medium- and high-riser heads, etc).
If you ever speak with him again in-person (yes, I know your truck is (was?) running), ask him to tell you about the time we took my black '82 Mercury Capri down to Welcome, MN (his home town), not only to see an old IMSA front-end he owned (I think he wanted to sell it to me), but also to just tear-up the streets (as well as my poor clutch)!
And tell him Jim K says, "Hi!"
Good guy, Tim. Very knowledgeable, and extremely meticulous and "customer driven". He's one of maybe three machinists I know who I would trust implicitly.
TMeyer Inc – Precision Automotive Machining & Manufacturing
Holy ****! You're White?
You always sounded like a dot Indian in my head.
Ha thought he was one of those blue ridge hillbillies I grew up with when I lived in Va on the good side of the Mason Dixon line
One of the good ole boyz
