Anybody have a template/measurements?
lead69
hopeless car junkie
Vancouver,Wa
Im looking for the measurements or a template of where to mount the dual scoops on a 71 duster hood,Im starting from scratch,thanks.
The hood on my '72 Demon is from a '70 with the dual scoops. Below are the measurements I took - you should be able to position them correctly with these.
The measurements I indicate are the flattest portion of the scoops, i.e., I didn't measure on the rounded corners on the back of the scoops, and are from the right or passenger side scoop. Obviously would be the same for the other side.
From hood ridge to front outside of scoop = 2-7/8".
From hood ridge to rear outside of scoop = 4-1/4".
From hood rear to rear outside of scoop = 2-3/4".
From hood rear to rear inside of scoop = 2".
From hood front (with hood front edge molding installed) to center front of scoop behind the chrome bezel = 24".
Hope this helps.
