Good morning, and here goes! I'm sure this has been asked before, but looking for the latest and greatest information. I'm looking to see if anyone has ever used Crane CR66542-16 roller lifters, 64629-16 pushrods, and 64792-1 Gold rockers together on the street. If so, what kind of service life can you expect with street only usage from the lifters and how often are you keeping up with lash adjustments? I realize they aren't BAM lifters. If the these parts are all part of a professionally built 440 based 505 short block assembly with eagle rotating assembly (4.25 stroke, 7.1 inch rods, MAHLE pistons) that we'll be picking up in the near future. The original intent of the build by the PO was street usage. The block has already had the lifter bores bushed, but I don't know yet if the lifter bore bushings have been drilled or hopefully slotted for oil delivery (I would hope they would be with street usage in mind). If they are, we'll probably be going with hydraulic rollers anyway. We have some used Stealth heads on the radar at the moment as we don't intend to rev it to the moon. Leaving power on the table is not as much of a concern as durability. Being it's intended as a low rpm primarily street use affair, we're looking at a Comp 274 XE solid roller, as the recommended valve spring pressures are very close to that for a hydraulic roller. https://www.compcams.com/xtreme-energy-236-242-solid-roller-cam-3-bolt-for-chrysler-383-440.htmle
Overall question, should we just go ahead and plan on a hydraulic roller cam with a set of Morel lifters? The only way it would be used with solid rollers is if we could expect a reasonable service life out of the Cranes because we've already got them.
