[SOLD] ARP pro series Ring Gear bolts for 8 3/4
72wedge
Northern Cali
Brand New!!! ARP pro series ring gear bolts. Part # 240-3001
I opened the package and realized they will not work on a 68’ and older sure grip, which I have. Holes in the flange are too small (.380) and needs to be drilled out (.390) to fit the wider shank diameter of the bolt. See pics for more info on application.
Please check your application to make sure these will work. Here’s a link to summit, they sell them for $40.
ARP Pro Series Ring Gear Bolts 240-3001
$25 shipped to your door
Have you found a source for the older (smaller shank diameter) bolts?
Nope. I’ve checked every source I could think of... unless there’s a place I don’t know of. I read somewhere on Moparts they only reproduce the bolts with the larger shank diameter. I ended up just using my original bolts, fortunately they’re in good condition.
