AUTO METER GAUGE WIRING HELP
WAYNE0
milton pa.
I just made a dash gauge cluster for my barracuda. I got a good deal on some auto meter gauges. speedo, tach, fuel, volts, water, oil gauges. I got the all wired in except for the lights. I know the black wires are gonna go to a ground & the white wires are going to a power source. I would like to hook them up so i can dim them just like the original dash lights. Anyone have an idea where i can hook them up to ?
The orange should be the correct wire BUT...
It is always helpful to know...
What car?
What year?
What modifications?
Do you know for sure that white on the auto meter is the illumination power feed and black is the ground?
I did the same thing. Yes auto meter is white for light feed. Yes also if you want to dim with the headlight use the orange wire(s). And as said provided you know where the orange wires come from and go on your specific model..Swingn’
That should read. “Dim with the headlight switch”…sorry for the typo..swingn’
its a 67 barracuda 397 ci 360 4spd all auto meter gauges
