[SOLD] Autometer gauge set
4spdragtop
Ontario Parts Unknown
Hi all, here's is a set of 5 used gauges i was going to use on run stand, but never did.
Gauges are vacuum, oil psi(mech), volts, clock(bent adj arm), fuel.
These are used in good shape, other than the clock with a bent adjustment arm.
2" gauge face.
Comes with 4 bulbs and 2 brackets.
$125 US shipped to lower 48 and Canada.
Thanks
Steve
I was asked about senders for abv gauges....I don't believe there is any required?? Correct me if I'm wrong ??
Oil psi is mech, so tubing required
Vac gauge...again tubing
Clock...electrical
Volts elec
Fuel would be the only one needing a sender correct?
Clock...electrical
Volts elec
Correct. The sender for fuel would just have to match the ohm reading for the gauge, but isn't supplied with said gauge.
