Mopar to ya
@$#%&%! I had a thread about this before, so here is the readers digest version and updates. I have some questions and really need advice. Here goes. Car ran great. I installed Comp Cam XE268H cam and lifter kit. Broke in, drove around town, life was good. Degreased underhood and backfired through exhaust immediately on start up. Figured it was wet and would dry out. No such luck. Since then:
turned to TDC, lined up timing marks, verified rotor pointing to #1
new plug wires
new plugs
new cap and rotor
checked for vacuum leaks, none found.
It started with this stuff, which is better than a few days ago. Even ran pretty good, but still popped every now and then. Warmed it up, got timing about right. Stopped popping, or so it seemed. turned idle down maybe 1/8 turn and it dropped idle hard and almost died. Backfired more. Throttle response sucked. Played with mixture screws. got throttle response and popping seemed to stop. Revved and let off, no popping. Go for test drive and as soon as I put it in gear it starts popping.
I am guessing I should do a compression check.
Can a bad or poorly adjusted carb cause backfiring through exhaust?
I am wondering if the ignition module is wet internally. It did get sprayed.
I am sorely in need of some Mopar wisdom. Anyone have any to spare?
new plug wires
new plugs
new cap and rotor
