Barke Question E to A
Cazbah362
Nevada
OK - have an entire disc brake setup from a 70 E body, will these work on my 71 A body?
OK, so if I had 73 greater upper control arms this would work? What about 68 B Body uppers for Disc brakes, will those control upper arms work
If you dont want to replace your upper control arms you can get an adapter for the small ball joint from DrDiff.
You don't want the '70 E-body spindles or rotors. 70-72 e body spindles have a different dimension on the inner wheel bearing, and originally used 2 piece rotors. They repop them now as 1 piece finally, but they still cost more than the '73 up rotors. Last I checked Autozone had them for around $80 per rotor. Not horrible, but the '73 up stuff is cheaper and you have more options (drilled/slotted/etc.) I think someone is making bearing spacers for these now, but I'd just find a '73 up set. Or use a set of F/M/J body spindles, they're easy enough to find in the wrecking yards.
Calipers and brackets should also be the pin type on the E-body stuff. Not a huge deal, just different from stock A body stuff.
As far as the UCA's, you'll need '73 up A body UCA's or the adaptors from Dr. Diff. None of the others will interchange.
