PRH
Things have been a bit slow on the BB forum, so I thought this might generate a few comments……
watching this hurts... i don't get the caveman thing that FI is bad... FI is amazing.. i have used it and love it. Him blaming everything on the FI is BS... also.. don't diag ****, just keep cranking. I just don't want FI on my old car cause i can't stand how it looks.. and all the wiring..
i'm fine with that and i use a carb... but the whole hating efi thing for no reason other than they don't understand it is silly... also blaming efi cause they didn't know the intake wasn't grounded is nuts...Because a decent carb will beat its ***.
Let’s be honest. For EFI to make power you end up with most of the **** guys whine about carbs.
Fixed it......That intake looks powdercoated.. so the gaskets insulate it from the block and the bolts aren't breaking the powder coating... bad ground.. must be the POORLY THOUGHT OUT FI
There’s def a lot to absorb from that video.
One thing I found kinda funny was how no one understood what was going on with the instructions for locking out an MSD distributor, and the whole “rotate it 180*” thing.
It hurt my head..... I don't get why the phasing was so far out.. that should have been fixable without a special rotor? Watching him get mad was kinda funny though... GRRR!!! FI BAD!!
lol he was dropping a few F bombs. I’ve never seen him do that before.
I found that funny though.
Me too.One thing I found kinda funny was how no one understood what was going on with the instructions for locking out an MSD distributor, and the whole “rotate it 180*” thing.
ohhhhh i finally saw the second Hemi video last night... and man..i hope RAMM didn't see it..... they **** on that motor bad.. basically said he's full of ****.. but they don't know his name... so.. but stillThis was as bad as that Hemi video.
No. The throttle bodies are not progressive on the outside carbs. 1:1 type linkage.Do the EFI six pak secondaries hit like a real six pak?
For the uninitiated when a properly tuned six pak hits it's secondaries it's a wild time, hold on
They could have chose the option to not have the fitec control the timing and the phasing would have been what it was originally with the distributor, locked or unlocked with should have been fine. That should have lead them to the problem being the phasing with the fitec controlling timing. If they followed the phasing procedure in the instructions they didn't show it in the video. I think they may have skipped over that part.It hurt my head..... I don't get why the phasing was so far out.. that should have been fixable without a special rotor? Watching him get mad was kinda funny though... GRRR!!! FI BAD!!
