Locomotion
* Comp Cams Steel Retainers 740-16 - $40.00
- 1.437" diameter
- For 10* locks
* Comp Cams Beehive Springs 26918-16 - $145.00/set
- 125lbs @ 1.800"
- 367lbs @ 1.160"
- Spring rate: 373lbs/in
- Coil bind - 1.100"
- 2 sets available
* Comp Cams Beehive Springs 26120-16 - $175.00/set
- 155lbs @ 1.889"
- 377lbs @ 1.289"
- Spring rate - 370lbs/in
- Coil bind - 1.230"
- 1 set available - Not pictured.
* Comp Cams Valve Locks 641-16 - $20.00
- 7* locks
- Machined Steel
- For standard single groove 3/8" valves.
- Standard installed height.
* Crower Valve Locks 86108-1 - $30.00
- 7* locks
- Machined, Chromoly
- + .050" installed height.
* Comp Cams Valve Locks 623-16 - $20.00 ***SALE PENDING***
- LS1 style
- 7* locks
- For single "round" groove 8mm-5/16" valves, including Magnum.
* Mopar Performance Race Coil P3690560 - $40.00
- requires 1/4 ohm ballast resistor.
* Taylor Plug Wire Separators 042860 - $12.00 for both.
- For 7-8mm wires.
- Blue
- One pack missing a 2 wire separator.
* Stewert Warner Oil Pressure Gauge 82406 (USED) - $10.00
- 5 to 100 PSI scale Full Sweep
- 2 5/8 in diameter size
- Analog gauge
- Uses Mechanical Sender
- Black Face with white pointer
(Has light socket but no oil line.)
All items are NEW, except SW oil pressure gauge. Some have been opened only for inspection or mock-up.
Beehive springs work great to eliminate rocker arm/retainer clearance issues. I just needed higher pressures for my applications.
Prices + shipping from Florida 32117
(Sorry, I don't do PayPal.)
- 1.437" diameter
- For 10* locks
- 125lbs @ 1.800"
- 367lbs @ 1.160"
- 2 sets available
- 155lbs @ 1.889"
- 377lbs @ 1.289"
- 7* locks
- Machined Steel
- 7* locks
- LS1 style
- 7* locks
- For 7-8mm wires.
- Blue
- Analog gauge
