Bellhousing id help
iw378
Suisun City, Ca
Just double checking my parts. The only casting numbers on this bellhousing are pictured below. I think it is a 3515734. Messed up number one. Can any of you 4 speed guys confirm this is correct ?
Brewers website says....
Reconditioned original 10.5" small block bellhousing cast #3515734 to fit 1972-4 A-body (will also fit 1967-1971 A-body if BSB734 bellhousing ballstud bracket is used) and 1972-4 E-body 318/340 3 & 4-speed applications, 4.354" bearing retainer opening, uses 130 tooth flywheel.
