Best valve cover gaskets
dustertogo
Brandon, MS
Hey guys, what valve cover gaskets have you found that hold up the best to the heat from stock exhaust manifolds?
Thanks
Dustertogo
Most any of them do. Feel-Pro is my fav.
90% of them not leaking is the Prep work. If the covers are not straight and crushed at the bolts they all leak.
At one time Fel-Pro had a part number for Police spec gaskets. Small block mid 80's.
Aspen,Diplomat,Grand Fury cop cars.
Bought some in the early 2000's. Maybe ?
Also, besides having a flat flange and not over-torquing, original sheet metal valve covers typically have football shaped, load spreading washers under the bolt heads.
