Big block 727 decoding help
73 Duster_forever 73
Active Member
Vancouver,Washington
I trying to figure out the past of this 727, any help is greatly appreciated.
if that number clocks as 4039539 then it's a 78 400/440, long HD extension and rear timing hole
What does the long hd mean and what does the rear timing hole do? Also the guy I got it from said he pulled it from a police interceptor, I do not remember the model. Would you be able to know if this is true.
Thank you
Can you give us all the numbers in your photo.
Some are hard to read.
1978 Chrysler parts catalog shows it's from a 1978 Ramcharger or Conventional cab pickup with 400 or 440 engine with 727 transmission and long heavy duty extension.
Date code 5835 is July 19 1977.
