Dumpsterpat
Member
$1600- Big block 727 with an A&A reverse manual transbrake valve body. Has an A&A bolt in sprag, billet servo & accumulator. This trans is a 1966 19 spline front pump with 4 clutch drums and 3 gear planetaries. Also has a deep pan on it and It's all in perfect working order. Newer Hurst pistol grip shifter with all the hardware. 3500 stall A&A converter that was stalling and performing flawlessly. Everything here is in great shape. I can deliver to the mopar nats in Columbus this weekend if you're interested. Thanks for looking!
