[FOR SALE] Big Block Mopar 1.6 Ratio Roller Rocker Arms - New
Rocket
CT
I have a set of new Mopar Performance 1.6 ratio roller rocker arms. These are made by Crane for Mopar and are the same as the Crane gold rockers. I do not have the shafts or other hardware.
Price is $285 shipped in the lower 48 states. PM me with any questions.
These rockers fit stock and stock replacement heads like Edelbrock. From what I read on line this morning these do for Stage VI heads. There was some discussion on versions of Stage VI (Chapman) having moved intake valves and those models require an offset intake. I can do more checking tonight.
These rockers do not require hard chromed shafts but you can use them if you have them. This link provides the shafts Crane sold with their gold rocker arms which are the same as these rocker arms - big block shaft part # 64619-2 which are ground steel.
Crane Pro-Series Rocker Arm Shafts 64619-2
I do not know the Mopar part numbers. You could use these Hughes engines shafts as one option. Rocker arms unlimited, Isky and Comp Cams may also have a suitable shaft to choose from.
You will also need rocker spacers, hold downs and bolts to run these just like iron adjustable big block rocker assemblies.
Hughes Engines
I have an old catalog from the early 1990’s and can get a part number from that date. Part numbers may have changed however.
