[Found!] bottom leaf from a 2835056 (68 Formula S) leaf pack
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I'm missing a bottom leaf from my spring pack
One of the bottom (smallest) leaf from a 2835056 (68 Formula S) leaf pack is hanging out with a sock somewhere. My media blaster has given up trying to find it.
Let me know what you have.
I would entertain a bottom spring from a different pack as long as it is the same length and center hole offset.
Thanks
Bottom leaf from a 1976 W200 4x4 front axle works as the lower "Big Block Leaf", just cut it to the same length with your chop saw and round the ends to look factory.
8 3/4 axle setup ^^^
I’ve got a set of these spring sitting in my garage, I can take a picture when I get home from work.
Thank you. I realley only need the bottom leaf BUT perhaps we can work out a deal.
I have the next up leaf from another spring pack ( unknown car) the arch is spot on and I have cut it to shape BUT i need to taper the leaf and I figured before I go to all that trouble I'll ask again. But thanks for the idea
You can have whatever leaf you want for $40 shipped if that sounds fair. If you want the whole spring minus the hanger/shackle it’s $20 plus actual shipping cost.
