ramhead
motor has ohio 3.75 stroke steel crank new,ross12 1/2 -1 pistons,eagle rods,indy billet rear main seal retainer,arp main studs,67 440 blk 30 over,all oiling work done on block with milodone single static line external oiling sys.Ultadyne 640 640 276 degres at .50 thous flat tappet cam,edelbrock rpm 84 cc heads with mild bowls,chambers,ports just cleaned up.Tm7 intake matched to heads and all ports cleaned up rocker arm specialtes rocker arms 1.5 ratio and billet shafts and spacers aluminumwater pump and housing,romic fluid dampner,tci flex plate,1000 hp anular discharge holley carb.All so cope racing bracket special trans reverse valve boby and billet (steel front drum)turbo action o69j convertor this combo has less than 25 miles and 4 1/4miles passes $5500.00 motor,1100.00 trans,600.00 convertor or best offers 1-414-581-3950 ask for mark zip code 53086 was in 73 dart sport
