[WANTED] brackets ( pictures)
whiteeagle
My Forefathers land Az.
Does anyone have an early /6 with A/C ( 2cyl compressor ) that you could send pictures of mounting and of brackets.?
Does anyone have spare brackets?
I am sure I can make them if need be if I knew what the heck they look like and where they go.
If you do.....Thanks alot
I have a set on a 69 if you are interested in just the brackets
does anyone have an early /6 with a/c ( 2cyl compressor ) that you could send pictures of mounting and of brackets.?
I am sure i can make them if need be if i knew what the heck they look like and where they go.
If you do.....thanks alot
not sure if this helps
i have a bunch of miscellaneous take off a/c items from several cars
all cheap before disposed of
What years are you interested in. I have a 65 wagon with a slant 6 and A/C mounted (but not working...)?
But it does have the stock compressor mounted on the front of the slant 6 if you need reference pictures.
